theoldwizard1
Jan 05, 2018Explorer II
dougrainer wrote:
AGM and Lithium batteries are heavier due to there is NO space between the plates for the electrolyte. So, the battery case is completely full of the lead type plates. Go to a battery store and pick up a 24 series lead acid deep cycle battery and then pick up the same 24 series AGM. You will be surprised at how much heavier the AGM is. Doug
Although it is difficult to find, deep cycle batteries of the same size as a regular flooded battery also weigh more.
Quick rule of thumb for the same sized batteries. More lead = more weight = more GOOD !
