time2roll
Jan 05, 2018Nomad
Almot wrote:Not sure I buy into that. The voltage does taper off and in a tight range compared to lead-acid so you just need more decimal places.
You would hardly notice the voltage change in this range. AH monitor is a must with these babies.
Actually I see this as being more accurate. Lithium voltage does not sag and bounce due to load like lead-acid. Also lithium should not need a disconnected 24 hour rest period to get an accurate reading.
For a flashlight it might be an issue but for an RV I don't see it.
ebay LED 3 decimal panel meter
