firemedic1992's avatar
May 12, 2014
Just installed JT Strongarm Stabilizers - What a difference!
I just installed the JT Strongarm stabilizers on my fifth wheel. What a huge difference!
I couldn't install the rear scissor jack stabilizers as I was supposed to in the instructions because there was no I beam to run the brackets to, so I ran them to the main frame rails (parallel with the frame). I used a ratcheting cargo bar between the two rear scissor jacks to stabilize the side to side sway, and it works great.
I can't get any movement in the trailer now, probably the best investment in the trailer to date!
  • Good to hear. I have a box sitting in the garage waiting to be installed. Can't wait.
  • Fully agree. Same experience here.
    For the rear I installed a section of 2"x2" square tubing across the rear of the trailer and bolted to the frame on each side. Attached the JTs to that tube.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
