Rmack1 wrote:
I have two Trojan T105+ deep cycles that I replaced my old 12 volt boat batteries with. Series wired, off course. I suspect I'll have more amp hours now.
Question; should I do any maintenance on those bad boys?
For heaven sakes yes! You must always make sure the acid/water level is kept above the plates in those wet cells. I check mine at least once each month....or more frequently depending on usage. Letting the battery acid get low enough to expose the plates will permanently damage the battery.
