MEXICOWANDERER wrote:
Ktmrfs
KUDOS for being a authentic GREEN minded individual.
Batteries that do not BUBBLE are batteries at risk. Not Old Faithful grade bubbling or Bikini Atoll H-bomb test bubbling but slight bubbling in every last cell. This is an excellent way to tell if your cycled batteries are being recharged correctly. Then use a hydrometer. Meters help.
Most of today's converters deliberately undercharge a battery to prevent the manufacturer from ending up in court being sued for boiling dry a battery. The new new converters are designed to protect know-it-all owners with double digit IQs. Plugger in and head for the brewskies.
mex:
thanks, but also thanks to you from which I added to my knowledge of battery technology and upkeep.
As for SG, I got one of the refractometer combo battery SG, antifreeze testers from amazon from a likely reasonably reputable company. then compared the results for SG with my Freese (sp) hydrometer. They matched very closely. Now I use the refractometer to check SG. IMHO it's much easier to get a repeatable reading. no more making sure the top of the tube is not touching on the side, etc. etc. and much quicker. I can check 4 batteries in the time it took to check 1 battery before. and the results are extremely repeatable.
and for equalizing and finish charging, luckily my new solar charge controller has a wide range of latitude in setting charge levels, so I set the float, equalize and bulk charge modes to what Trojan recomends. that means I can set equalize to 16V, I just turn off the power to the trailer, and leave the charge line to the batteries turned on and let er rip on a nice sunny day a few times each year.
and somewhere stashed in pdf files is info from WFCO talking about why their charges are so hard to get into bulk mode charging. Basically exactly the reason you specified. They had to many complaints about dry batteries, so they changed the algorithm to avoid this, which basically makes the WFCO a 13.6V charge in most any case, and very difficult to get into the 14.6 V bulk mode. Which also means forever to get a battery anywhere near full charge.
