bgradert's avatar
bgradert
Kayak Rack - Ladder Rack
All-
I am researching truck racks to haul two 9.5 foot kayaks. Are there any specifics things I should be aware of? I am looking for a no drill application and my tow vehicle is a 2015 f150 Ecoboost.
  • I have a system that works great for us.
    We have a F150 CC.
    We carry 2- 12 foot kayaks on racks and folding bikes in the bed.
    We have a Thule roof rack that mounts about center of the rear door. ( Thule has a option for you to buy just one rack rather than a pair. ) We have a Yakima single bar rack that mounts about 2 feet from the rear of the truck. Both are easily removed. I take mine off when not in use. I have a toolbox and could not find rear racks that did not interfere with the toolbox. These racks are not cheap but make a rock solid rack system. I made a roller out of pvc pipe covered with foam on the rear rack so we can roll the kayaks up and down to load.
    I can add a picture and look up the name of the place I found them if you are interested.
  • We have a platform of sorts for two kayaks that is lowered onto or raised from our canopy rack. We park under them when not hauling. Never owned a truck without a canopy so don't know how we'd handle hauling kayaks that way.
  • Gjac's avatar
    Gjac
    Explorer III
    bgradert wrote:
    Gjac wrote:
    Do you want to store them in the truck bed, on top off the cab, on top of the cover for the bed or on the ladder of the RV?
    We usually carry 4 bikes with us that I keep in the truck bed. My thoughts were to buy a truck rack and place the kayaks on the rack. Or, purchase a Stromberg Carlson bike bunk and put the bikes on the bunk and slide the 9.5ft kayaks in the back of tow vehicle. My only concern with that set up is when I turn sharp, my fear the kayak will hit the bikes.
    I would like to refrain from removing the tonneu cover as much as possible.
    If that is the case I would store the kayaks on the roof of the truck if you plan to use them frequently or on top of the trailer for infrequent use like if you are planning a long trip out west. One thing I learned over the years the harder it is to remove the stuff you want to use the less your want to use it. I store my kayak on top of my tow car for local camping and use an inflatable raft for long trips like Alaska.
  • Gjac's avatar
    Gjac
    Explorer III
  • I have Trac Rac with Kayaks and also have Tonneau cover. My cover is "inside box" model that leaves the stake pockets open so I can install rack.
  • I have a tonneu cover on my truck. Be nice to have something that would fit on top of the cover.
  • I picked up a pair of Yakima Outdoorsman racks off Craigslist. It has 60" bars hauling one canoe but I also have a set of 78" bars if I want to double up.
  • Can't help with a truck cab rack, sorry.
    But have been very happy with my truck cap (topper) rack.
    You order the cap with built in rails then choose the racks you want.
    I just got the square tube Thule cross rails, and used foam kayak blocks and rope (heavy duty, but thin, small engine pull cord rope).
    Only issue is you need a stool or small ladder to access it all.
    Good Luck.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
