MEXICOWANDERER
Sep 14, 2019Explorer
Gordon Three has absolutely the correct answer. Unless a person themselves with their own hands diagnosed and themselves repaired converters and power supplies, what are they doing inside a repair thread? My former 400-watt Megawatt now called Hyperwatt. is now a constant duty 650-watt charger with utter success.
The full-wave bridge rectifiers inside these units should have a heat sink and most do not.
The capacitance of all capacitors must remain the same value. But stay away from Chinese landfill. Something Mr. G3 missed is temperature. Stick with 105c units, his list of acceptable brands is impeccable. If a 300 volt or 400-volt capacitor will fit, use it.
If a unit uses a Schottky rectifier rated 80 amps over the original 30 amps and 150 volts PIV over 100 USE THEM.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
