BFL13
Nov 26, 2014Explorer II
wwest wrote:Army11Bravo wrote:
Here's to keeping my batteries healthy through the winter. I have them in a heated garage, wired in parallel, and attached to a trickle charger. I'll keep an eye on the water level every couple weeks, and fill with distilled water as needed.
I've learned much from these forums. Thanks, everyone!
The weaker battery will soak up most of, if not all, of the charging current.
Even if it does, does that mean the stronger battery won't get enough?
The usual story is that with all the power from the float charger, each in parallel will get what it needs and be ok. Where you get trouble is leaving the two in parallel with no float charger.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
