rekoj71
Dec 31, 2015Explorer
I like the foam idea but think that gluing some 1 inch sheet foam like they sell at HD for walls might be cheaper than the spray stuff, but might use the spray glue to stick it. They also sell Liquid Nails caulk like adhesive for foam board but would want to be sure it would bond to the poly tank bottom.
Not sure on the discharge tube. The above idea is probably the best but a little costly for such a short trip, though you might be able to remove it and use it again somewhere. If you use antifreeze or rock salt (no experience) I would be wary of over diluting it as you fill up the tanks.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
