Wayne_Dohnal
Oct 04, 2014Explorer
On the Honda Fit with GPS (maybe all other Hondas with GPS?), when you turn the key to unlock the steering column, the GPS runs, cooling fan and all. The Fit in particular has a silly looking miniature battery. As much as I like Hondas I think their GPS power operation is all screwed up. EVERY time you start the car, you have to press the GPS's CYA button to use it. But the unit un-powers when cranking the engine, so if you program it before starting the engine, you have to do the CYA button and setting the GPS mode over again. Seems about as backwards as backwards can be.
