dougrainer
Dec 20, 2016Nomad
doxiemom11 wrote:
Look for an owners manual online for the Atwood furnace model that you have. There should be troubleshooting tips as it sounds like the same problem we had when the ignitor just needed to be adjusted to that the flame would light. You may also just have dirty connections, a critter nest, mud daubers, dirty burner etc causing the problems. There is usually an access door on the outside for this purpose. Maybe the manual will also instruct on how to remove. I think Bryant RV has the manuals online that you can view or download for free. Do a google search and it should pop right up.
AS I stated, He has the L/D model which is a specific model that has NO access from inside or outside for service or repair. You have to pull the complete furnace for repair access on your work bench. IF the OEM did not make access for removal, then you may have to remove the refer and then the wood refer cabinet floor to remove the furnace. Doug
