fj12ryder
Jun 26, 2017Explorer III
You refer to solenoid valves but the system is hydraulic, right? It's possible your ram is bleeding off pressure due to a bad seal in the ram. Since it's just the bedroom that doesn't come all the way in it's unlikely to be the hydraulic system itself. If the system wasn't building or holding pressure you'd be more likely to have issues with the larger slide.
You might check the condition of the floor where the ram is mounted that pulls the slide. We have a Fuzion 383 that had the floor damaged and the ram pulled loose from the floor.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
