flip418's avatar
flip418
Keystone interior wall thickness?
I have a 2012 Keystone Cougar 328QBS. I want to install a coat rack on a outside wall interior of the coach but not sure how thick the walls are. It is solid when pushing on it. I cannot find any technical information aside from calling the factory! Help?
1 Reply
  • It is 1/8" luan (or there about) with 1.5" (or there about) solid foam, then another layer of luan and then filon for outside.
    I have hung coat hooks, magazine racks, etc with no problems to these walls. I have found that using 1/2" wood screws and no drilling for pilot holes works best. Do not use screw gun bit just slow firm pressure with screwdriver to get screws to bite into the wood. Do not over tighten, just a little beyond snug will keep things solid. Make sure you limit the weight of whatever you are using hooks or racks for.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
