KendallP
May 28, 2014Explorer
Gale Hawkins wrote:
Ours read well from grid or our 5000 Kohler Confidant. What load were you running? If it is normal (125v or less) with the AC running you should be fine.
With A/C running, it shows more like 127v or so. But also 60 hz and 1.0 power factor.
I had posted something about my proud generator tuning a week or 2 ago. The Kill-a-Watt pretty well shows steady voltage until I max out the load. Then it actually climbs above 130... which doesn't thrill me. But I virtually never need to run that kind of load, i.e. the A/C and electric heater on at the same time.
The KAW also shows a very steady frequency between 59.9 and 60.1, again, regardless of load. So if the KAW is accurate, then the genny is performing pretty dang well.
