TomG2ExplorerMay 07, 2018Killer AmpsI want to pull ten amps out of a little 35 ah battery for one hour and then fully recharge. Will this heavy draw destroy the battery? I know it is a small battery.
pianotunaNomad IIIMay 08, 2018If all he wants is heat then 4 1156 bulbs will give him about 96 watts. Or if he wants that little amount of heat, he could light a candle.If the battery is deep cycle then 10 amps Peukert adjusted becomes 17 amps of load.Better to run a 12 volt electric blanket and be under it if you want to be warm.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
Related Content80 amp converter and eu2000iI am the truck killer!Borax Ant Killer.-- Cheap and Effectivekiller air conditioner30 Amp VS 50 Amp
