TomG2
May 08, 2018Explorer
Killer Amps
I want to pull ten amps out of a little 35 ah battery for one hour and then fully recharge. Will this heavy draw destroy the battery? I know it is a small battery.
TomG2 wrote:
Test report:
I was wrong on the wattage. I was wrong on the wattage. It is a 250 watt electric heater, which explains why it performs okay on shore power. The result was that the 400 watt inverter immediately went into low voltage shutdown with the application of the 250 watt load. Won't work with the 35 ah battery. Might work with a Group 27 battery, which I will try someday. Little battery is still handy for light loads and I will put up with cool mornings if I have to. No, I am not going to buy a 100 watt heater to see if that works.
