jd_h's avatar
jd_h
Kitchen sink blocked
Kitchen sink won't drain. Pipes under sink removed, all clear. Snake used by rv tech did no good. Went out 24 feetonly takes about a quart or so of water to back up into sink. But are clear out much further.
Help. Any tdeas?
Thank you,
J.D.
  • I had a Montana which had the galley tank drain behind the rear street side tire. Did not know it for 3 months. (Can you tell how much I cook/wash dishes?) Does your monitor panel show a galley tank reading?
  • You might have an air lock. Do you have an air admittance valve that might be defective? Is the roof vent open and clear?
    A quick test-while the sink is not emptying, pull the dump valve. If it’s an air lock the sink should start flowing.
  • Empty the gray water tank.
    How many gray water tanks do you have?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
