deltamaster
Oct 19, 2014Explorer
My kitchen faucet is exactly like the cheap contractor grade found at any Home Depot. I suspect (given other things I have replaced) that a new cheap contractor grade faucet from Home Depot, Lowes, or even Walmart would work just fine. As long as the fittings are the same, which they should be as was the case with my bathroom faucet, then ANY residential faucet will fit as long as it fits in the holes in the sink or counter. Heck, upgrade to a nice one! After all the faucet is nothing more than a glorified valve. The fresh water pump does not need a special faucet, only thing it knows is the line has been opened so it needs to pump when the pressure drops.
I say buy whatever you like and whatever fits in the space and spend a couple hours with some ordinary hand tools and DIY that leaky thing!
Just remember to shut off the water before you take it apart!
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
