I have a 1989 chevy van conversion.I had trouble with the door latch operating in its correct manner.The parts in the door would not move and I would have to hold the door button depressed to line up ...
WD is like gas oil pre mix you run in a 2 stroke. Whole bunch of solvent reducing some oil, making it very, very thin and penetrating, solvent evaporates off leaving a thin film of oil. Good if with every piston stroke or cycle you are getting a fresh dose of solvent and oil, like in an engine.
Not good if you aren't lubricating frequently or every operating cycle. Lubrication then is not sustaining.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
