j-d
Sep 09, 2013Explorer II
Mike, Traveling Circus, Traveling Teacher...gotta be a joke there someplace.
Before you try what I'm going to say, you must disconnect power from the step mechanism. Then...
Can you disconnect the motor arm from the steps and see how tight they are to operate? The motor will not move the steps if it senses what I'll call Opposition. When fully Open or fully Closed, that's Opposition, and the control unit stops the motor. Probably based on current draw. It doesn't use limit switches, just Opposition.
If the steps are tight to move, that's Opposition and the motor won't run. Easiest case would be to continue to work on the steps and get them to fold and unfold freely. Then you'd have electric operation again.
Manual Steps fold in a way that they cannot open without a lifting/pulling motion. If you want to disconnect the motor and make yours manual, your issue will be to make up a way to be sure they cannot fall open on the road.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
