965Racer
May 04, 2009Explorer
rad valve wrote:
Kwikee will not have that high torque motor they have not used that motor for a couple years. The AM equiment motor took it's place.
I pulled the motor today. The AM motor would be great, but there's a problem. The AM 214 is definitely the right size, thickness, etc., but the hole pattern for mounting is the 11 degree type that the smaller AM 210 motor uses, not the higher degree version that the AM 214 uses. So I need the hole pattern of the 210, but the torque of the 214. Weird.
Any further suggestions?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
