USMC46's avatar
USMC46
L1 OP Code on Norcold Fridge--Help (Norcold Recall Issue)
Early this A.M., our Norcold fridge, Model R1210M started beeping and we are getting the code L1 OP on the fridge control LED readout on front of the unit. I went outside; removed the cover, and the red LED light on the Temperature Sensor device installed to prevent fires (recall fix) is lit up. On this forum, others indicate they have had this problem and that the problem is that the installed Temperature Sensor safety device failed. But, I do yet have a good understanding of WHY the devices have been shutting fridges down. My question is to those who have had the same problem: Was it just a failure of the Temp Sensor safety device, or is it usually a failure of some more expensive / important part of the fridge that triggered the devise to shut the fridge down ? This morning, I will call the RV dealer here in Corpus Christi that installed the device a few years ago (in response to the Norcold recall) and see if I can get it in quick for a check. But I would like to hear from anyone who has had a similar failure, so I can judge the response of the RV techs who will be looking at it. Thanks for any advice.
  • LI OP means "line open" I believe. When our 1210 did this, we had to replace the cooling unit. The boiler was oozing yellow fluid and it was shot. No fix for it, ours anyway. In our case, the switch kicked out which was what it was supposed to do to prevent a possible fire. We had a replacement cooling unit put in by National Refrigeration in Shipshewana.
    You may call Leon, the young Amish owner, and talk with him. He will give you information you can trust. If he doesn't answer, leave a message and he will return your call. He works alone, so doesn't have anyone to answer the phone.
    Our has worked flawlessly since his rebuild was installed. . . better even than before. He is an approved Norcold and Dometic service and Good Sam Extended Warranty worked.
    Dale
  • I have had the code and light. Reset with a magnet moved over the box by the red light. It is to prevent fires from overheating. Have seen NO sign of overheating. Believe most are a false alarm.
