doughere
Jul 19, 2015Explorer
midnightsadie wrote:
we rarely use the electric side of the frig, gas cools faster,,better so instead of your rv siting on a dealers lot for a month, just use the gas. and it,ll run for weeks on a tank of fuel.remember start the frig 23hrs before you load it. we load some at 12hrs or so. that way the doors not open very long.add a small fan inside the frig it,ll cool things faster.and even out the inside temp. and remember your frig uses 12volt for the controls so charge your battery before leaving.
We do lots of dry camping, we rely on solar; use gas on the refrig extensively. If its working fine on LP I'd wait to work on it until you return from vacation; no need to see if you can cause more problems dickering with it now.
Get a copy of the repair manual read it while on vacation, by the time you return you will know all about how to fix it.
Good Luck,
Doug
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
