RLS7201
Nov 03, 2016Explorer II
Bumpyroad wrote:dougrainer wrote:fitznj wrote:
I've had 2 Alum sided and 1 Smooth sided TT.
The Alum Siding if easier to fix if you dent a panel. Ours is 10 years old
now and still looks brand new.
Our only smoothie had a leak and delaminated 4 years into our ownership.
As a result - I have a bias towards Alum Siding
Why is it easier to fix if you dent a panel? Doug
yep, that makes no sense to me. do you start pulling off pieces at the bottom and work up to the dent, then replace? a fiberglass sided RV can easily be repaired either with white Bondo, or at a boat yard. I can't visualize an individual repairing a hole with fiberglass cloth and resin and end up with less than an unsightly patch.
and if you are in hail country, aluminum would be a disaster.
bumpy
You cut out the damaged piece, snap in one edge of the new piece, bend new panel over a piece if 2" PVC, have helper pull out PVC slowly as you snap in the other edge. Replace corner trim.
Yeah! I was amazed too when I saw it done.
Richard
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
