dougrainer
Nov 03, 2016Nomad
RLS7201 wrote:Bumpyroad wrote:dougrainer wrote:fitznj wrote:
I've had 2 Alum sided and 1 Smooth sided TT.
The Alum Siding if easier to fix if you dent a panel. Ours is 10 years old
now and still looks brand new.
Our only smoothie had a leak and delaminated 4 years into our ownership.
As a result - I have a bias towards Alum Siding
Why is it easier to fix if you dent a panel? Doug
yep, that makes no sense to me. do you start pulling off pieces at the bottom and work up to the dent, then replace? a fiberglass sided RV can easily be repaired either with white Bondo, or at a boat yard. I can't visualize an individual repairing a hole with fiberglass cloth and resin and end up with less than an unsightly patch.
and if you are in hail country, aluminum would be a disaster.
bumpy
You cut out the damaged piece, snap in one edge of the new piece, bend new panel over a piece if 2" PVC, have helper pull out PVC slowly as you snap in the other edge. Replace corner trim.
Yeah! I was amazed too when I saw it done.
Richard
IF the metal is wider than 12 inches, you can do what you stated. IF the metal is less than 12 inches, regardless of how careful you are, you will put small dents when you try to bend/roll the metal back in. The metal only has so much give before it creases. Very few RV's now have metal wider than 12 inches. Most are 10 inches. You still have to remove the corner moldings and windows/doors/anything on that piece of metal. That adds labor time and cost. PLUS, if you have any decals you have to factor that in. YOU DO NOT CUT OUT THE DAMAGED PIECE. That is NEVER done. Also, HOW do you then staple the new metal "S" lock to the studs? Doug(someone who has done RV metal work for 37 years).
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
