wannabegone
Nov 25, 2016Explorer
westend this crossed my mind but since the White is listed in the wiring diagram as a system ground, negative circuit on the 12v system, and the Blue/White as a furnace ground I don't this that will work either, beside I touched the wires together and nothing happened. I don't remember if I had the switch to heat or not though.
Chris I'm going to check the A/C and Furnace models when I get out to the TC, since it is raining looks like it'll be sooner than expected. According to Lance's wiring diagram there are no connection between the a/c unit and the furnace. Actually the only diagram I have of the 2 shows the Blue/White wire as (-) to the thermostat and a Blue wire (+) to nowhere stating "not used" meaning I need to find the furnace model to find a diagram as to how it is wired became in a 12v system it either + or - are missing nothing iis work. I'm also hoping the DVM will ahead some light on how the thermostats work.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
