wannabegone
Nov 25, 2016Explorer
So looking atvthe information I've got in front on me it looks like the a/c unit is a RVP Products 9000 series and the furnace is a Atwood 8500-IV 2 stage series furnace.
According to the wiring diagram I found on the furnace paper work the furnace should have a + and - to or from the thermostat and + and - 12VDC from the battery or converter. With the rain so far today I have not pulled the exterior furnace cover. So far I have found the Blue/White wire to be grounded all of the time and terminal 8 of the thermostat where the Blue/White wire connects to be some type of resistor or something. When the B/W wire is connected and the system off DVM connected between 12+ and terminal 8 of the thermostat 13.3V with the thermostat switched to heat and the furnace commanded the voltage is continually fluctuating from 3V to 8V. With the B/W wire disconnected when off DVM connected between 12+ and terminal 8 1.46V on 2.56V.
The Honeywell thermostat is going to be a little more difficult to get this information due to the design but hopeful I'll be able to post that shortly.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
