Old-Biscuit
Aug 12, 2013Explorer III
Shouldn't be 'hitting the stops'.......that may be why your motor is struggling and blowing fuse.
From your link....
WARNING!
DO NOT OVER EXTEND NOR OVER RETRACT ELECTRIC LANDING GEAR. OVER EXTENDING THE LANDING GEAR MAY RESULT IN DAMAGE TO THE DRIVE SHAFT PUTTING THE UNIT IN AN UNSAFE CONDITION AND WILL NOT BE COVERED BY LCI LIMITED WARRANTY
Also note....
POWER OPERATION
Prior to operation, be sure battery is fully charged. Low voltage may result in damage to the electrical portion of the system
Check if that 25A fuse is correct size.
Our single motor legs uses a 30A.
From your link....
WARNING!
Also note....
POWER OPERATION
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
