Almost all laptop AC power supplies (from the simplest wall wart to the biggest brick) contain a transformer, which heats up during use.
Proper design would suggest that some form of heat discharge needs to be built into the case, but most of them are built on the cheapo.
So, it doesn't matter what campground you're at; as long as it's plugged into a shore power 120 VAC outlet, it'll get hot!
It's only dangerous if the adapter is sitting on something extremely flammable -- like your lap! Most countertops, furniture, etc. should be OK, but check them periodically, just to be safe.
