zigzagrv
Apr 30, 2015Explorer
First, your generator should be putting out a pure sine wave. Modified sine waves are put out by low cost inverters.
Secondly, get a Kill-O-Watt monitor (very inexpensive) and plug into your receptacle. It will tell you what the voltage and frequency output of your generator is.
Voltage should be around 120 volts and the frequency should be 60 hertz. I would suspect the laptop charger as the problem.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
