MrWizard
Apr 30, 2015Moderator
I suspect an outlet problem, or inverter transfer switch problem
Was the outlet used with shore power the same outlet used while traveling and running the generator?
Was it the exact same test, playing movies while plugged into shore power?
Was the A/c running during the shore power test
One a/c should not being the voltage down so low, as too affect the laptop charger
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
