willald's avatar
willald
Explorer II
Apr 30, 2015
Laptop use on generator power question
..Pretty sure I know the answer to this, but here goes:
Early last month, we tried for the first time, to let the kids use our laptop to watch DVD movies in the RV when on the road. Had the generator running (needed it for air conditioning), so had them plug laptop charger in, so it could keep the laptop batteries from draining.
We quickly found out, that this did not work. Laptop batteries quickly depleted; even when plugged in, they would NOT recharge at all. When plugged into generator power, laptop would work OK even with battery stone dead, but battery would not recharge running off of genny power. When we got to our destination and hooked up to shore power, of course, the laptop batteries charged up quickly and easily.
Sooo, on generator power (Generator is Cummins Onan 5500 watt unit), laptop batteries will not recharge, but will power the laptop itself.
I'm almost certain, this is because our generator must not be putting out true sine wave power (probably modified sine wave?), and the laptop charger cannot charge the batteries because of this. Or, is there something entirely different wrong here? The laptop is a fairly new model, I got it last December, its a Lenovo.
Pretty sure the only realistic solution here, if we want batteries to stay charged up when on the road, is to install a small true sine wave inverter, and wire it to 12V power. Upgrading the Motorhome's generator to one that puts out a true sine wave output is not going to happen, is definitely NOT worth that.
Are there any other solutions to this, that I'm not thinking of? Would I might be able to get a charger for the Lenovo laptop, that would work off of 12 volts?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
