mchero's avatar
mchero
LCBU (Light Bar Control Unit) failure!
07 Freightliner LBCU failure!
Started the rig couple days ago and noticed the blank display. Gauges still working thankfully but display is blank. I cycled the off/on rapidly and saw the Freightliner text for just a second but back to blank, backlit screen.
Took the LBCU down to the boards, inspected and cleaned with contact cleaner. Also cleaned the ribbon connector as well but no change.
I will need to replace the unit before I get the yearly inspection because that frekin display shows the odometer!
Called Freightliner and was told the part number is A06-57187-004. Called Freightliner of New Hampshire and was quoted $596.00!
Just thought I'd give others with LBCu a heads up! Sick to my stomach but I see no other options.
Ideas, thoughts, if any welcome.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
