stevenal's avatar
stevenal
Nomad II
Nov 14, 2016
lead in water
With lead in water making the news lately, I decided to do some testing at home. With all new 2006 cpvc plumbing, I didn't expect to see much of a problem, but was concerned about the 2006 brass fixtures. Sure enough, the first draw off of a bathroom sink faucet exceeded the federal limit. It looks like the newer versions of the very same faucet models are built to stricter standards, so I'm starting to change them out one by one. Looking a bit further out, the camper water supply is my next concern. The camper has Quest plumbing and plastic faucets, so I should be in great shape. However, I generally fill the tank prior to leaving home from an outdoor faucet. Using the same logic as before, perhaps I can perform an exact swap. Looking at http://www.woodfordmfg.com/woodford/LowLeadLaw.html, I see the manufacturer has easily sidestepped the law by claiming they don't anticipate anyone using these faucets to supply water for human consumption. And not even a warning label on the new faucets to indicate this determination. So there you have it. Not only must we take our chances on the road with old pre- safe water drinking act equipment, the newest equipment may not be any better. I suggest we start informing the manufacturers how we use this stuff so they can adjust their anticipations. And in the meantime, let the water run awhile to flush out the lead before filling your tank or taking a drink when hooked up.
  • Remember, the first bit of water to come out of a faucet after sitting a while may test high for lead but just a few seconds of flushing the water standing in the fixture should provide water meeting the supplier's specs. I doubt water passing through a fixture picks up any testable level of lead contamination.
  • None of those changes will make any difference if the lead is in your water supply. You can get a quality report on your water from your provider.
  • After all the years of drinking hot water from a rubber garden hose, eating/chewing on lead based paint growing up, wallowing in Red Lead paint in NAVY bilges along with the 30 yrs exposure to asbestos I doubt a little lead leaching from a brass fixture is going to cause ME an issues.
    My Immune System was heavily assaulted and has survived.....:B
