Artum_Snowbird
Jul 10, 2018Explorer
I wonder about the weight on the front and the back of the center axle? By the look of the position of the hangers, the front of the center spring is pushing down heavier, and the back of the center spring is lighter.
If this is the same on both sides, you could measure the distance from the front of the spring to the axle and see if possibly the U bolts should be moved a bit forward on the spring pack.
I would definitely have a spring shop give you an expert opinion.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
