wopachop's avatar
wopachop
Leaf spring shackles are tilted
My friends are saying its from the force of the trailer brakes? Its a triple axle and all the shackles stay tilted like this even after driving down flat roads.
The shackle will bottom out on the frame while going down driveways. Seems wrong. I tried making it straight with a jack but it bounces right back.
Should i slam the trailer brakes will driving in reverse?
  • N-Trouble wrote:
    time2roll wrote:
    Hanger is mounted slightly off. In the foreground the hanger needs to be positioned to the left a bit.
    Say what?? ALL the equalizers are at the same angle.
    Yes the error appears to be very balanced and consistent.
    Could be the spacing has changed if the springs are worn and flattened.
  • Thanks everyone the trailer is sitting on flat ground and i used a level on the frame.
  • amxpress wrote:
    Adjust your brakes and drive on.
    Reduce pressure? Im pretty sure the trailer has been like this for a year. Even after multiple trips. Its like this resting position is somehow locked in.
    Was thinking i could drive in reverse and hit the manual trailer brake button. Get it all to shift back. Thats just a guess.
  • Take it to a trailer shop and have them check the spacing of the axles. Hard to tell from that picture if the trailer isn't sitting level.
  • Its pretty obvious from the pic the trailer is sitting nose high. There’s your answer...
  • Hanger is mounted slightly off. In the foreground the hanger needs to be positioned to the left a bit.
  • It moves all the time in relation to bumps and other surface irregularities. For instance, in your pic it looks like the trailer is nose up in relation to the ground so they will sit like that.
    It's acting perfectly normal.
  • The equalizer moves as the driving surface changes or trailer load distribution changes. Is your trailer sitting level in the picture? Springs show the same bow? Tires and axles the same?
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 22, 2025
