Roger10378
Oct 11, 2022Explorer II
I think you fixed it.
Several years ago I had noticed a slight odor from my gray tank when it was about 3/4 full. I figured out that it was coming from where the drain pipe went into the top of the tank. Further investigation showed the the tank had a rubber grommet that the pipe went thru and the floor forced the pipe slightly to the side which deformed the grommet so that it leaked. A few minutes with a Dremel and no more smell. At least I had easy access to the problem area.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
