work2fish's avatar
work2fish
Leak from hot water heater
Hi Folks,
I've been having a great time with my new camper this summer. I especially like that I can just stop anywhere to camp and do this on a whim since everything is packed and ready to go.
I noticed that when I had my hot water heater on, there is a constant dripping of water drops coming from one of the spigots, here:
It only drips when the hot water heater is on. I'm guessing that this is not normal, but the only way to fix it would be to put some sort of plug in that spigot. Can anybody tell me why this might be happening?
Thanks,
Mike
  • I would bet that your relief valve is just slightly leaking, both water and air. After some time, the relief valve will bleed off the air and only water will remain.
    These relief valves have an o-ring that is the usual cause of failure but it can also be a misaligned piston/seat or failed spring. I've had older ones fail with a single cycle of opening and closing.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
