I have a rubber roof and had some leaks and used eternabond tape.The tape fixed all the leaks but around the skylight in the bathroom i can see the carpet fabric around the skylight getting wet when i...
I had a leak where water dripped at one corner of the skylight. It turned out that the leak was about 3 feet from the drip, coming in at the far side of the bathroom vent.
It can appear at locations other than where it is entering the camper.
My issue turned out to be that the previous owner tried to seal the leak originally with silicone, then Dicor, and then Eternabond. Eternabond is pretty good but surface must be clean and per the manufacturer cannot be silicone.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
