I have a rubber roof and had some leaks and used eternabond tape.The tape fixed all the leaks but around the skylight in the bathroom i can see the carpet fabric around the skylight getting wet when i...
^^^^^^^^This is the first thing I would check. Could be a small crack down near the mounting flange. If not, go in expanding circles around the skylight until you find a likely suspect.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
