TBammer's avatar
TBammer
Leaky slide or what?
The floor was spongy near the rear of the trailer and when I peeled up the linoleum I found a lot of wet plywood. I have no idea where the water came from. The shelving under the sink is dry. Can the slide leak (no topper) if left open in the rain? I can fix the floor, but how do I trace the leak? Ideas? Leaking condensate from the fridge maybe?
  • Another source of leaks can be through the tail lights and or the running lights.
    Pull the slide out and spray around it with a hose....simulating rain. Have someone inside watch...
  • Have you inspected the seals (wipers) on the top and sides of the slide-out?
    If they are deteriorating or crimped, not lying flat, water can get in.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
