MEXICOWANDERER
Jul 03, 2017Explorer
Learning 101 Thermistors
Too old of dog... :(
Thermistor range needed hopefully near zero but 10 ohms will do fine.
Upper resistance 200 ohms
Inverse operation. Meaning lower temperature to 0°F the lower the resistance.
Upper range 200 ohms at 50c or 122°F.
Of couse I can use a pull-up resistor within reason.
I need to narrow the performance window then concentrate on getting a bullet proof package. A thermistor to be glued or screwed onto a battery lug with leads to a weather pack terminal.
I forgot to bring my Newark catalog. Too many sites encourage contact with a traveling salesman. Tacos over techtalk?
Thank you and yes the thermistor is for what you think it is...the power supplies.
A part number and spec sheet would be wunderbar...
Thank You
Thank You
