wittmeba
Nov 03, 2013Explorer
Usually hairline cracks are only in the Gelcoat surface finish. They can be fixed with Gelcoat repair but does not affect the structure - only cosmetic.
Walmart:
http://www.walmart.com/ip/Evercoat-100668-Marine-Match-N-Patch-Gelcoat-Repair-Kit/21784220
Home Depot:
http://www.homedepot.com/p/Aquatic-Gel-Coat-Repair-Kit-35RKWH/100177610#.UnZnRKKc4rg
As indicated if you are seeing fiberglass the problem is deeper than Gelcoat. Should have a fiberglass (boat or car) specialist take a look.
Walmart:
Home Depot:
