N-Trouble's avatar
N-Trouble
Leaving black tank filled
Im pretty religious about dumping my tanks after each outing but this last trip pulled a brain fart and forgot to dump and have put the trailer in storage. Contemplating whether I should pull it out and dump or just wait til next outing? Tank is only about 1/4-1/3 full and no sign of odors yet. Pull it out and dump or leave??
  • put some RV-Digest it in the tank and then it will be liquid by the time you use it again
  • I would also say depends on how long. Over time heavy solids will settle to the bottom and may be harder to flush out.
  • Bleach will kill the beneficial bacteria in a holding tank. Just leave it alone till next time, assuming there is plenty of water in the tank.
  • Depends on how long it will sit idle.
    If it's more than a month, I'd take it out for a dump. The solids can clump together and make big floating island that would be hard to dump later.
    And I would also give it an extra dose of "toilet chemical" or bleach and soap if you don't dump it.
  • I empty mine every 2nd or 3rd outing, as a single guy, I don't generate much black water over a short weekend. The gray tank, that's usually after every 2nd, as I waste a lot of water washing hands and dishes.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
