Gdetrailer
Mar 01, 2014Explorer III
Grumpy374 wrote:
Thanks for the replies everyone.
And yes, the new wireing is for standard 120v. Just adding a new 30 amp breaker with correct wireing for the 30 amp MH plug. It will be dedicated to just the outside receptacle for the MH.
Grumpy
I think BFL was pointing out that even though you have a 120V 30A RV receptacle, not EVERY "electrician" understands or KNOWS to wire it with 120V.
Instead, it OFTEN gets miswired with 240V.
A 120V 30A RV receptacle LOOKS a lot like a 240V 30A DRIER RECEPTACLE.
YOU MUST CHECK the voltage on the receptacle BEFORE PLUGGING IN YOUR RV.
Check the breaker in the breaker box, it MUST be a SINGLE POLE breaker for 120V. If the electrician puts in a DOUBLE POLE breaker DO NOT plug your RV in.
If you fail to check don't blame us...
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
