wa8yxm
Mar 01, 2014Explorer III
One word of caution.. If you hire the electrican MEASURE THE VOLTAGE on that outlet before you plug in
You should see, depending on the pins, 120, 120 and zero. If you see 240 (anything over 150) he did it wrong.
now to answer your question: Depends on the converter.
Magnetek 6300.. No way do you leave it plugged in till you upgrade
Progressive 9200,, There is no upgrade so go right ahead.
Others.. Well, read the converter manual. If it is a good quality 3-stage.. Plug it in. If not Upgrade.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
