IAMICHABOD
Mar 01, 2014Explorer III
Always keep it plugged in while at home. To do so it is good to have a 4 stage converter/charger. Like the 4 stage Progressive Dynamics converter, it has a Boost Mode, Normal Mode, a Storage Mode and a Equalize Mode to eliminate battery sulfation and stratification…the leading cause of battery failure.
Mine came with a Bi-Directional Isolator Relay Delay or a BIRD as they are called.
This allows me to charge ALL the batteries at one time while plugged in.
The controller also senses heavy loads on either battery to prevent the wrong battery from being inadvertently discharged
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
