lanerd
Mar 01, 2014Explorer II
sch911 wrote:lanerd wrote:
Grumpy... it depends upon your inverter.
Actually I'm sure you meant "converter". An inverter is designed to deplete your batteries.
No, I meant "inverter" as most have a three stage "converter" built in just to charge the batteries....but they are still called "inverters".
If you don't have an "inverter" then you can't use the batteries for items that require 120vac. You don't see many rv's anymore that only have "converters" in them.
Ron
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
