pianotuna
Mar 02, 2014Nomad III
Hi,
Sorry BFL13, but my research suggest your figures for gassing don't quite work.
From a spreadsheet that I found online. Temperature range is -30c (-22 f) to 50 c (122 f). It is unlikely that 13.8 volts is going to cause gassing, except in places such as Mesa, AZ, in the worst of the summer heat (gassing at 50 C (122 f)). 14.4 will at 21 C (70 f) and up. At -25 c (-13 f) 14.4 is not enough to even fully charge the battery bank. I've observed that happen this winter. So thank goodness I have solar. It is also good that I can charge either bank from solar.
It also means at 20 c (68 f) and below, that the PD "shot" of 14.4 every 20 hours for 15 minutes does absolutely nothing to destratify the batteries.
Another conclusion is that below -30 c (-22 f) there is no way to adequately charge the battery bank unless the disconnect switch is used to prevent damage to the various computer boards in the Fridge and etc.
I know these numbers "fly in the face" of folks with single stage 13.8 volt converters--but that is because the battery itself is above the ambient temperatures. Conclusion? For good charging, battery temperature needs to be monitored.
These numbers are why I wanted (and shortly will have) temperature compensated shore power charging.
temperature in C, charge voltage, gassing voltage
-30 16.2 19.2
-25 15.12 18.78
-20 14.04 17.82
-15 13.99 16.86
-10 13.92 15.9
-5 13.86 15.57
0 13.8 15.24
5 13.74 15.03
10 13.68 14.82
15 13.62 14.655
20 13.56 14.49
25 13.5 14.34
30 13.44 14.19
35 13.38 14.055
40 13.32 13.98
45 13.26 13.89
50 13.2 13.8
-30 16.2 19.2
-25 15.12 18.78
-20 14.04 17.82
-15 13.99 16.86
-10 13.92 15.9
-5 13.86 15.57
0 13.8 15.24
5 13.74 15.03
10 13.68 14.82
15 13.62 14.655
20 13.56 14.49
25 13.5 14.34
30 13.44 14.19
35 13.38 14.055
40 13.32 13.98
45 13.26 13.89
50 13.2 13.8
