RJsfishin
Jan 23, 2017Explorer
Believe anything you want to. But I'm tellin you that lead acid batteries all have the same float voltage, what ever that mite be. They all use the same electrolyte, and that is what determines the proper float voltage, not just because the battery has a different name on it, or that a MFG decides to try something different for a change ??
There is no way a batt MFG can give a correct float voltage w/o giving the ambient temperature along w/ it. Truth be known, (find a chart) proper float voltage is cold weather will be well over 14 volts, where as in hot weather it better not be over 13.2.
Now, there goes your batt MFGs recommended float voltages !!
So, go ahead and float your batteries (any) at 13.6 in hot weather, and see what happens !
And then there are so many here that have been falsely led into thinking that floating at too hi a voltage, is no problem, as long as you keep pouring water to them,....as if water is the only thing leaving the battery ?? Well, what is that nasty acid smell when a battery is floating at 13.8 in hot weather ??
I, and I'd bet many others have proved years ago that having to water a battery often, will shorten its life by a lot !
dawzie wrote:
Have a 2016 Montana 293RK purchased 7/16. Plugged in most of the time 24/7. Have a WFCO WF-9800 series converter. My fan runs variable speed and only on load. Fan is starting to growl when it runs, so adding that to repair list when we return to the northeast.
Did not know there are batteries with different float charge rating. My dealer installed a NAPA RV battery, so I will check into that.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
